1 - 11 of 11 Posts
Banned
Burtman Industries is proud to offer the PML Extra Capacity Transmission Pan for the Nissan Armada. We can also get any other PML item, so always ask!
PML’s Nissan transmission pan helps keep your tranny oil cool in three ways. First, the pan adds 3.5 additional quarts of oil capacity. Second, the pan features raised fins on the outside to help get rid of heat. Third, PML designed cast-in baffles on the inside of the pan that keep oil near the filter inlet, prevent sloshing, and aid in heat transfer from the oil to the pan. All this aids in less wear and tear on your transmission.
The tranny pan also features a cast-in boss that can be drilled and tapped for a temperature sensor, 3/16-inch thick wall to add strength to the transmission case, 3/8-inch thick gasket flange for a secure seal, and a magnetic drain plug for easier, less messy maintenance. Pan is available in as-cast, black, and polished finishes.
Also, be sure to check out the matching PML Differential Cover for the ultimate combo.
Increased oil capacity for cooler temperatures, 3.5 qts. over stock!
Sand-cast aluminum with raised fins
3/16-inch thick wall construction to add strength to the transmission case
3/8-inch thick gasket flange will not bend when bolts are tightened
Machined gasket surface for a secure seal
Boss cast into pan can be machined for a temperature sensor
Magnetic drain plug for easier, less messy maintenance
Mounting hardware provided
Gasket and filter not included (use stock parts)
Burtman Industries PML Deep Transmission Pan, ORDER HERE
We also have for QX56.
Are these in stock for immediate shipping? Or is there a turnaround time from PML once an order is placed? Thanks.
I'll be placing an order by next week, but for the RE5R05A low profile pan. I don't tow and just want to replace the rusted OE pan.
I ordered the oversize PML deep pan from your website yesterday. Thanks for the good deal and supporting the Armada forums.
1 - 11 of 11 Posts
