Have a 2013, and having intermittent issues with starting. Turn key and it is situation normal ( radio comes on, lights everything as you would expect), right up until I get a hum and then nothing. Turn ignition back off and on again same thing.. Turn part way, shift out of park, then back into park, wiggle shifter left and right and unlock steering, turn off then back on and fires up like nothing happened. This occurs either frequently (several times a day for a few days) or will go months without happening. Sometimes it takes 1-2 tries to start following above procedures (making sure to hold tongue just right sometimes helps as well) or other times may take 5-10 tries and walking away p*ssed off and back to try 20min later and it starts. On other threads and sites I have heard of everything from IDPM ECM Relay replacement, IDPM Board Replacement and Neutral Safety Switch replacement... Any have similar issues. *Note- it has never stalled while driving or loss of power, issue is only when starting truck.
Thanks in advance for any thoughts or ideas on above..
