1 - 15 of 15 Posts
Some of us Titan owners just notice that in the instrument cluster where the trip-meter and "P" "D" area, there's a digital readout (at least the outline) of a digital "MPH" and rear sonar guage (look like it has a "meter"). Do you guys/gals have this and does it work?
Haven't noticed, but I'll look this afternoon. ;)
Can see something
I have a 4x2, I can see the outline fo the 4x4 on the right side of the trip readout and the PRND321. I can see there is something to the left as well but can't make it out. Is this what you are talking about? I referenced the user manual and see no reference to anything over there. I have never seen anything light up over there either. Probably ideas that were cut out to save money.
Discussion Starter · #4 ·
Yes that is correct, I have a 4x2 Titan and have that same 4x4 outline. To the left of it is the one I'm talking about. Since you have a Mada and it don't work for you, maybe its for QX56 or even a future option.
My guess, and this is in no way a educated guess, is it was a safety call. If your looking at this small area for mph or for backing I think it would be inherently dangerous while the truck is moving. Just a thought.
Discussion Starter · #7 · (Edited)
In the quest to find out about this I found something I didn't know before. With the ign. off press and hold the reset button for about 10 sec. now turn key on (no need to start engine) continue to hold till you see "test" now you can scroll thru the menu by pushing the reset button. Stuff came up like telling me about octane and stuffs, it will also test all your bulbs on the cluster, will test all your guages and needles.
VIDEO here.
impex4 said:
maybe laser cruise for qx56 ?
Yes that indicator that you are referring to is the meter for setting up the distances on the laser for the Qx56. It's for short, medium, and long distance.
WOW, I am going to have to check this out. Interesting stuff. By the way, link does not work.
· SHIFT_Moderator
So that whole area is for laser cruise isn't it??? Did it make it into production??? Just curious if it could be mod'd into our Armadas/Titans. :D
nyc2005armada said:
..... By the way, link does not work.
That's what happens when we open up 3 year old threads. :D
Here's something I found in a old post over on TT, maybe this will be of some help. Oh, I don't think you want to try to MOD the laser over on to an Armada, it would be way more fun to do than you could imagine. I had to rewire a Qx56 for one once, a lot of work!!!!!!!!
For all you tech geeks, here is a break down of all the different entries in diagnostic mode. There is a oil pressure, entry, but unfortunately the output is in Hex, so that's not very natural too look at..
COMBINATION METER SELF-DIAGNOSIS MODE FUNCTIONS
Self-Diagnosis Mode functions Table
DISPLAY: nrXXXX
Displays hex ROM rev as
stored in NVM.
DISPLAY: GAGE
Performs sweep of all
gauges, then displays
present gauge values.
Performs checksum tests
on ROM and EE.
Gauges sweep within 10 seconds
DISPLAYAll segments illuminated)
Lights all odometer/trip
meter, fuel, and engine
temperature display segments.
Initiating self-diagnosis mode
complete
DISPLAY: bulb
Illuminates all micro-controlled
lamps/LEDs
regardless of SW configuration.
DISPLAY:EE XX, FAIL
DISPLAY:Sc1XX
Displays 8-bit software
configuration value in Hex
format.
Bit Coding
7-3 = reserved for future use
2 = TCS/VDC 0 = not present
1 = present
1 = Shift type 0 = Column shift
1 = Floor shift
0 = ICC 0 = not present
1 = present
DISPLAY:Sc2XX
format.
Bit coding
7-0 = Reserved for future use
DISPLAY:EprXX
format.
Bit Coding
7-2 = reserved for future use
1 = A/T Oil Temp (gauge)
0 = not present
1 = present
1 = Odo Units 0 = kilometers
1 = miles
DISPLAY:1nFXX
Displays 8-bit market info
value in Hex format.
$31 = USA
$2A = Canada
DISPLAY:cYLXX
Displays 8-bit engine configuration
value in Hex
format.
$08 = 8 cylinder
$06 = 6 cylinder
DISPLAY:FFXXXX
Displays 16-bit fuel flow
constant "Q" in tenths of
cc/min in Hex format.
$0000 - $FFFF
DISPLAY:tF
Displays 16-bit tire factor
"A" in hundredths in Hex
format.
$0000 - $FFFF
DISPLAYt1XX
Displays oil pressure telltale
"on" threshold in A/D
counts in Hex format.
$00 - $FF
DISPLAYt0XX
"off" threshold in A/D
$00 - $FF
DISPLAY: XXXXX
Raw uncompensated
english speed value in
hundredths of MPH.
Speedometer indicates
present speed.
Will display "-----" if message is
not received. Will display
"99999" if data received is
invalid
DISPLAY: XXXXX
Raw uncompensated
metric speed value in
hundredths of KPH.
present speed.
invalid
DISPLAY: tXXXX
Tachometer value in
RPM. Tachometer indicates
present RPM.
not received.
DISPLAY: F1 XXXX
Present ratioed fuel level
A/D input 1 in decimal format.
Fuel gauge indicates
present filtered level.
000-009 = Short circuit
010-254 = Normal range
255 = Open circuit
--- = Missing 5 seconds
DISPLAY: XXXC
Last temperature gauge
input value in degrees C.
Temperature gauge indicates
present filtered temperature.
Will display "---"C if message is
not received.
Will display "999" if data
received is invalid.
DISPLAY: BAtXX.X
Estimated present battery
voltage.
DISPLAY: rES -X
Seat belt buckle switch
LH status.
1= Buckled
0 = Unbuckled
DISPLAY: PA -XX
Hex value port A.
DISPLAY: Pb -XX
Hex value port B.
DISPLAY: PE -XX
Hex value port E.
DISPLAY: PL -XX
Hex value port L.
DISPLAY: P6 -XX
Hex value port K.
DISPLAY: Pn -XX
Hex value port M.
DISPLAY: PP -XX
Hex value port P.
DISPLAY: PS -XX
Hex value port S.
DISPLAY: Pt -XX
Hex value port T.
DISPLAY: Pu -XX
Hex value port U.
DISPLAY: P4 -XX
Hex value port V.
DISPLAY: Puu -XX
Hex value port W.
DISPLAY: A01XXX
A/D port A/D value (nonratioed).
0-255
DISPLAY: A02XXX
0-255
DISPLAY: A03XXX
0-255
DISPLAY: A04XXX
0-255
DISPLAY: A05XXX
0-255
DISPLAY: A06XXX
0-255
DISPLAY: A07XXX
0-255
DISPLAY: A08XXX
0-255
DISPLAY: A09XXX
0-255
DISPLAY: A10XXX
0-255
DISPLAY: A11XXX
0-255
DISPLAY: A12XXX
0-255
DISPLAY: A13XXX
0-255
DISPLAY: A14XXX
0-255
DISPLAY: A15XXX
0-255
DISPLAY: PA0-XX
Hex value representing
state of A/D ports 0-7.
DISPLAY: PA1-XX
Event Odometer Display Description of Test/Data Notes:
DISPLAY: Thr-XXX
Decimal value of thermistor
A/D reading.
0-255
DISPLAY: D-HI Meter/LCD Illumination.
Full daytime brightness all
LCD segments active
DISPLAY: N-HI Meter/LCD Illumination.
Full nighttime brightness all
LCD segments active
DISPLAY: N-LO Meter/LCD Illumination.
Min. nighttime brightness all
LCD segments active
DISPLAY: GAGE
Return to beginning of selfdiagnosis.
Hex EE level. If EE
checksum fault exists,
display alternates
between "EE XX" and
"FAIL".
DISPLAY: dtXXXX
Hex coding of final manufacturing
test date.
That would be pretty cool though, i think it would be worth the time to mod it over if it were possible. hmmmmmmm that would be nice. I think the wife would flip out if she saw our Mada's wiring all spaghettied out though. i would have to send her to her moms for a little vacation first.
1 - 15 of 15 Posts
