Will the rear turn signals from a infiniti QX56 fit on a 04 armada? Like the design better. The rear ones on my armada look like their from a durango. Anyone have ideas if their interchangable?
Why not add an auxiliary light (like a small fog light) under the bumper for a reverse light?RKS said:won't work, no reverse lights in them. the qx has them in the lift gate.
Campfamily said:Why not add an auxiliary light (like a small fog light) under the bumper for a reverse light?
Agreed, but wouldn't be all that hard. Would need to run a wire from the reverse light circuit to the new reverse light location, and find a good location to mount the light.RKS said:there is a lot of stuff we can do this is not a turn-key solution however.
true, which in some cases will lead the system to think there is no bulb, or to blink faster than ususal or just not work properly, this is solved with a resistor added to the circuit to make it consume as much as the incandescent bulbs...i would assume the QX56 tails have that resistor included into the own board...EightmanVT said:Moving from incandescent bulbs to LEDs will only reduce the power consumption....
Naw, it wasn't attached. He had to create/fabricate it!luigi'smada said:jajaj founf it efore you did...lol. thanks...
do you know how the fiber glass filler was attached to the tail lights ?? and how was the fiber glass piece made or where can it be purchased ??
thanks
Luigi
