I was wondering if anyone has had the rear AC lines repaired without having to replace the whole assembly from front to back? I already had these lines replaced back in 2012 on my 08 Armada and now there is a new leak where the small high pressure line enters the rear evaporator. I refuse to pay for this again as I think the whole design concept is totally flawed. During my research of this problem, I found a TSB (NTB08-110) that was issued back in 2008 which was supposed to provide all dealers with a tool kit to repair these lines on the vehicle. Despite this, it seems that most (if not all) dealers convince their customers that the only way to fix this problem is to replace the complete assembly (4 lines approx. 12' long), thereby requiring the separation of the body from the chassis to accommodate this. The tool manufacturer claims that it works fine and that GM uses it. I'm curious as to why Nissan dealers don't even acknowledge it exits.
Thanks.
Here is a link to the TSB. http://www.370zcoupe.com/TSB/1SD30.pdf
Thanks.
