I recently rotated my tires and noticed both rear wheels had excessive wear on the inside. I then did a visual on the camber and did a rough measure with a straight edge and angle finder on the wheel itself and found the angle to be approximately -1.4 degrees.
Anyone else have (had) this problem?
BTW...I have never had any alignment adjustment.
Also, is there any impact of the self-leveling shocks on camber. I noticed existing wheel well height to be at 35.4" where specs call for just over 36".
Wonder if the camber adjustment is covered under warranty?
Thanks,
Kevin (04 Armada LE)
Thanks,
