1 - 20 of 26 Posts
I know there was a topic as to what gear lube to put in your rear diff.
I was wondering if anyone changed it themselves or paid to have it done. I am planning to do it myself and I was wondering if any issues popped up before I start.
Looks like pull the drain plug, let it run, and refill up to the fill hole until it comes out.
Syko
Looks like it is about that simple. I am also thinking about changing out motor oil to Mobil 1 and diff. to a synthetic also. Just picked up Service Manual CD on ebay 10 bucks!
Thanks,
I already switched to Mobil 1 5W-30 in the engine. I will be changing to Mobil 1 80W-90 in the rear diff. I use a K&N brand oil filter. $9.00 is kind of steep for an oil filter, but how much is a new engine? Just something to think about.
I think I have to invest in one of the service manuals.
Syko
04 Nissan Armada SE
Off Road
Big Tow
Journey Package
315 70 R17 BFGoodrich A/T K/O
Syko
It is very difficult to pour gear oil directly from the bottle into the diff. You may want to buy some adapter for gear oil to pour the oil in the diff. I ended up buying an adpater which will fit the gear oil container on one end and the other end is about 1 1/2 foot plastic pipe but it still took a lot of time to pour the oil in the diff. I read on TT or CT that there are some kind of Pumps available to tranfer the oil. I will look for those next time. I used 75-140 Super tech from Wall mart. you may also need to use Nissan recommended thread sealant which I purchased from Auto zone for about $18.
What's the name of the thread sealer that Nissan recommends? Or can I use a Loc-tite brand thread sealer.
Syko
Rear diff oil change
I changed the oil in my rear diff yesterday. My rig has just done 3000 miles. The oil drained out looked a little skubbier that I thought it would - so I figure the $10 for new oil was money well spent.
I put Havoline Durablend (semi-synthetic) in. Would have used fully synthetic but my local Auto Zone didn't have any in the right grade (80w90).
A couple of comments have appeared on the site about thread sealant. There wasn't any on the plugs I took out. Both plugs have a sealing washer on them like the engine sump plug - so I didn't put any sealant on when they went back. No leaks evident overnight.
I got the oil into the diff using the plastic bottles it came in - didn't need any additional equipment.
My diff sucks
Well you guys are all talking about rear diff's but my main problem with this mada has been the front diff and axle it has broken 2 time no off roading aor towing of any kind has been done with this vehicle. It i currently at the service department now but I have already contacted nissan on the lemmon law. I have also had brake judder auto roll up and bad cabin booming, want to unload this and get an 05.
Syko
There is one OEM listed that I dont have the part number right now. They also listed an equivalent permatex 56521.
Nissan part # 999MP -AM002P
"Use High Performance Thread sealer or equivilent"
I would think you could use any appropriate thread sealer available at your autoparts store.
If I pull the plugs and have washers like David notes and no sealant trace I'll skip it too.
JUst had mine changed out yesterday at the dealer. $99.00. For me it is worth it just to let them do it. :schla24:
easy money
If you have a gear lube hand pump that fits in a gallon container the job is a piece of cake, it takes about 10 min and about $8 of lube. It is 4 times easier than changing motor/oil/filter.
I knew it had to be easy, after all the dealer only charged $99 (lol). Well at least they put the new brake fix on at 3,000 miles. It was just the 1st time I mentioned the juder.
Discussion Starter · #13 ·
Hey Cillyone
What type of gear lube do you use? I used Penzoil 80W-90 API GL-5 multi-purpose. This said I didn't have to use any additives for our limited slip rearends so I tried it.
Syko
I currently have the same Penzoil in mine, but I buy any major brand GL-5 that is on sale. The Armada does not have a differential type limited slip; it is an open differential, no need for additives. The “limited slip” is done with the (VDC) brakes; the brake is applied to the spinning wheel.
Correction: the proper acyoynom is "ABLS" Active Brake Limited-slip Differential
Looking Better
Just changed F&R diff gear oil for 3rd time and the oil I drained out looked much better than the 1st and 2nd and with very little crud on magnet.
Discussion Starter · #16 ·
Front Diff
I found the drain for the front diff, but where is the fill point. I haven't gotten my service CD yet so I am still learning on this vehicle.
Syko
Front diff fill point
Remove the small skid plate near diff. Just loosen the front two bolts (skid plate slotted) and remove the two in the rear and slide plate off. The fill hole is up on the passenger side of diff. My plugs required just the 3/8” square drive of a socket extension to remove them. You need a little more than a gallon to do both F&R.
Discussion Starter · #18 ·
Thanks Cillyone,
I'll crawl under again tomorrow and see what I find.
Syko
Are you sure your drain plugs are 3/8" square drive? My Rear diff drain plugs are both 10mm allen wrench. Just curious if Nissan is putting on different drain plugs on different Armadas?
10mm hex in rear 3/8" front
Yep, 10mm allen hex in rear and 3/8" square in front, go figure.
1 - 20 of 26 Posts
