1 - 3 of 3 Posts
Hi All!
I'm going to attempt to repair the rear window release latch on my rear hatch.
it's a manual setup, no electrics.
When I pull the smaller actuator handle on my Rear Hatch, it feel like it's not connected to anything.
Also, would like help taking off the Hatch interior trim panel so I can look, without breaking it.
Any thoughts would be greatly appreciated!
Mike McLeod, 2011 Armada SV
hi,
i recommend , if you have not already, download the nissan factory service manual - its avail online if you look. its the same shop manual the nissan techs use. that's the best way to understand the procedures to do the repair you seek.
The little wire cable came off the pink colored part that connects to the latch I had the same issue and mine is a ‘04 it’s pretty easy to put on but takes longer to get the trim pieces off
1 - 3 of 3 Posts
