Anytime I use the rear window washer to clean the window, the nozzle where the fluid comes out will continue to leak for a couple of days. So I know either the nozzle is cracked or maybe the hose connected to the nozzle is somewhat loose or disconnected.
I took it to Nissan & even though I'm fully covered with my warranty, they still wanted to charge me $150 just to take a look at it to see what the issue is. Does anybody know what this issue could be & if it's an easy fix?? Could I just replace the rear brake light where it's located?
I placed some tape around the nozzle to keep it from leaking.
50142
in your sig looks like you have a first gen armada so check out the attachments.
you will have to remove the back door finisher, and the spoiler to gain access to this.
Thanks!! I figured I would have to take it off in order to see the problem, but was hoping maybe somebody had a similar problem with an easy fix. I'll work on it this weekend. Thanks again!
