There has been much discussion here about the "new" brakes on our Armadas. There also seems to be a lot of confusion about what the new brake fix consists of. I hope this post will help members to understand what the fix is.
1. The new rotors are for the front only. They are not larger in diameter and they are not thicker. They have been redesigned to stop the warping. Look at the attached links for the pictures (from Greg at MossyPerformance). These pictures will explain the differences.
2. Calipers are not being replaced. New pads are installed with the new rotors, as well as some new caliper mounting hardware.
3. Some dealers are turning the rear rotors and installing new rear pads when they install the new front rotors. I don't know if they inspect the rear brakes and make the decision to turn the rotors at that time or if some are just automatically doing the rears.
4. The dealer will turn the rotors up to three times (as long as they meet minimum thickness) and install new pads before the new rotors are installed.
5. As far as I know, at this time there is no recall for the brakes planned. The dealers won't repair the brakes until the customer has a complaint.
Here are the links to the pictures:
http://www.mossyperformance.com/rotor1.jpg
http://www.mossyperformance.com/rotor2.jpg
