I don't have the kit, but I think its attached with the 3m adhesive, don't take my word for it, but if you check the wood dash kit threads, you might find what you are looking forsptddog said:
I don't have the kit, but I think its attached with the 3m adhesive, don't take my word for it, but if you check the wood dash kit threads, you might find what you are looking forsptddog said:I'm considering buying an 04 LE with what I assume is an aftermarket wood dash kit. It looks nice, but it's not my thing. Unless of course I end up getting used to it.Anyhow, can these be removed? Would it ruin what is below it?
TIA...
I have the Burtman Red Burl wood dash kit on my Armada 2004 and love it. I believe Jason said that it can be removed for those especially that are only leasing their Armada.sptddog said:I'm considering buying an 04 LE with what I assume is an aftermarket wood dash kit. It looks nice, but it's not my thing. Unless of course I end up getting used to it.Anyhow, can these be removed? Would it ruin what is below it?
TIA...
This is correct with our kit, but MOST other kits require the use of a "adhesive promotor" that you wipe on before install - they use a cheaper adhesive that needs this to stick properly. BUT, when you remove the kit, the factory plastic underneath will be discolored. You somehow need to find out who made that kit.mich05 said:I have the Burtman Red Burl wood dash kit on my Armada 2004 and love it. I believe Jason said that it can be removed for those especially that are only leasing their Armada.
