1 - 8 of 8 Posts
I have purchased a pair of Bosch Wiper arm but couldnt figure out how to remove the OEM arm assembly. Did someone remove one and how you did it?
Wiper Arm Removal/Installation
Removal and Installation for Front Wiper Arms, Adjustment for Wiper Arms
Stop Location EKS006QR
REMOVAL
1. Operate the wiper motor, and stop it at the auto stop position.
2. Remove the wiper arm mounting covers.
3. Remove the wiper arm mounting nuts, then remove the wiper arms.
INSTALLATION
1. Prior to wiper arm installation, turn on wiper switch to operate
wiper motor and then turn it “OFF” (Auto Stop).
2. Lift the blade up and then set it down onto glass surface to set
the blade center to clearance “L1” & “L2” immediately before
tightening nut.
3. Eject washer fluid. Turn on wiper switch to operate wiper motor
and then turn it “OFF”.
4. Ensure that wiper blades stop within clearance “L1” & “L2”.
Before reinstalling wiper arm, clean up the pivot area as illustrated.
This will reduce possibility of wiper arm looseness.
Tighten wiper arm nuts to specified torque.
Removal and Installation for Wiper Motor and Linkage EKS006QS
REMOVAL
2. Remove wiper arms from the vehicle. Refer to WW-31, "Removal and Installation for Front Wiper Arms,
Adjustment for Wiper Arms Stop Location" .
3. Remove the cowl top extension. Refer to EI-17, "COWL TOP" .
4. Disconnect wiper motor connector.
5. Remove cowl top extension bracket.
Clearance “L1” : 41.5 - 56.5 mm (1.634 - 2.224 in)
Clearance “L2” : 52.5 - 67.5 mm (2.067 - 2.657 in)
Front wiper arm
nuts
: 23.6 N•m
(2.4 kg-m, 17 ft-lb)
SEL543TA
SEL024J
LKIA0408E
1. Wiper arm mounting covers 2. Wiper arm mounting nuts 3. Front RH wiper arm and blade assembly
4. Wiper frame mounting bolts 5. Wiper frame assembly 6. Wiper motor to frame mounting bolts
7. Wiper motor mounting spacer 8. Wiper motor 9. Front LH wiper arm and blade assembly
FRONT WIPER AND WASHER SYSTEM
6. Remove wiper frame assembly mounting bolts, and remove
wiper frame assembly.
7. Remove wiper motor from wiper frame assembly.
INSTALLATION
CAUTION:
Do not drop the wiper motor or cause it to contact other parts.
Check the grease conditions of the motor arm and wiper link joint(s). Apply grease if necessary.
1. Connect wiper motor to connector. Turn the wiper switch ON to operate wiper motor, then turn the wiper
switch OFF (auto stop).
2. Disconnect wiper motor connector.
3. Install wiper motor to wiper frame assembly, and install assembly into the vehicle.
4. Install cowl top extension bracket.
5. Connect wiper motor connector. Turn the wiper switch ON to operate the wiper motor, then turn wiper
6. Install cowl top extension. Refer to EI-17, "COWL TOP" .
7. Install wiper arms. Refer to WW-31, "Removal and Installation for Front Wiper Arms, Adjustment for Wiper
Washer Nozzle Adjustment EKS006QT
This vehicle is equipped with non-adjustable washer nozzles.
If not satisfied with washer fluid spray coverage, confirm that the
washer nozzle is installed correctly.
If the washer nozzle is installed correctly, and the washer fluid
spray coverage is not satisfactory, replace washer nozzle.
This may help. As they say, "A picture is worth a thousand words."
See attachment
Reactions: snorky18
Discussion Starter · #4 ·
Hey SCR,
Thanks for the detailed instructions. I think I used the wrong word but I am looking to change the wiper blade assembly (Wiper with tensioners etc). I think it whould be a simple procedure but I didnt want to break anything.
changezi said:
Hey SCR,
Look in your owners manual in the "Maintenance and do-it yourself" section. It is near the back of the book, section 8, I think. There are instructions and a drawing there to change the blades.
Do anyone else's wipers go down for a split second when you first turn them on, then go back up for the full stroke? If it matters this is an 06 QX56.
Mine wipers ride high on the windshield, and drive me a bit nuts. I was going to adjust them per the service manual (thanks SCR38), when I noticed there is a clean worn spot on the windshield where my wipers are wiping BELOW their resting/off postion. That clean worn spot is located much closer to what L1 and L2 should be.
My 24" driver side wiper is currently running over the trim at the top edge of the windshield, but I wasn't sure if this adjustment would resolve that or not (depends on the new upper limit position).
L1 (driver side) clearance per service manual: 1.6"-2.2"
My L1 (driver side) clearance in the off position: 6.5"
My L1 (driver side) minimum clearance when wipers go down before back up: 2.7"
L2 (passenger side) clearance per service manual: 2.0"-2.6"
My L2 (passenger side) clearance in the off position: 3.5"
My L2 (passenger side) minimum clearance when wipers go down before back up: 1.5"
This happened on my wife's Maxima after we replaced the wiper motor. Due to the odd placement of the motor, it was hard to get everything lined up just right, so it stops the blade right before it finishes the stroke and then actually finishes going down once the wipers are turned back on.
My guess is the wiper motor was replaced and when it was installed, it wasn't aligned properly. I have no idea how easy it is to align in the Armada, but after about 30 minutes of fiddling with it on my wife's car, me and my dad gave up and said it was "good enough".
1 - 8 of 8 Posts
