Hi, I have a 2011 Platinum and the passenger side mirror glass is cracked. I can either replace the whole assembly or just the glass but am looking for videos/instructions on how to do it?
Link to the service manual for your year for the mirrors here - https://www.nicoclub.com/FSM/Armada/2011/MIR.pdf
I did this on the pass side of my 06 - replaced the whole mirror because I found a used set cheap. The power, folding, auto-dimming, turn signal mirrors are not cheap. The link has info on replacing the whole mirror or just the glass.
Easy job. Basically look for a cover plate / plastic piece inside to door. Mine was a thin piece of plastic glued on - I heated it with a heat gun and pealed it off so i could reuse it. Under there are some nuts or bolts to take off (that hold the mirror on) and a wire connector. That's it. Easy easy. Best tip is to roll the window down so you can catch the mirror.
Thanks. Did you need to take the door panel off, or was everything accessible behind the cover plate/strip?
No need to take the door panel off on my 06. All behind that little plate.
