1 - 13 of 13 Posts
Have seen some people say cut it out, not sure where they go about this... I have a reciprocating saw.
The air line also won’t come out...PITA.
Do you have a torch? You can pick up a cheap one from AutoZone (or its competitors ) for like $15 or less. Heat up the nut and spray WD-40 (PB Blaster smells better though) into the threads. The heat and expanding nut will suck it in. You'll have to do that a few times, and then try to break the nut loose. All of my shock bolts were a PITA when I replaced the shocks.
A 1/2" impact gun also helps out big time. I bought a Milwaukee 1/2" cordless dugga-dugga after dealing with some stubborn nuts/bolts.
I have a cordless Dewalt with a 1/2" connector (it's interchangeable though). Doesn't seem to put a ton of torque on it. I just need to break it free, I think. Other three came out without issue, just this bottom driver's side one.
Stupid air hose won't disconnect from this one either and I think I buggered up the valve release trying for it. Probably need to just pull it out when I get the shock off. Other one of those was difficult as well.
Discussion Starter #4
Oh, I do have a torch, I'll try that tonight. Was a bit afraid with the rubber there though. Also things been soaked in enough WD40 and PB to start a grill at this point. Should have evaporated by now though.
I'd like to think that if three of the nuts broke free then you'd eventually have luck with the fourth. Try the torch. I believe I've read somewhere that steel expands .001" per 100*F increase... or something like that.
Are you able to rotate the bolt head to access the entire circumference ? That can help when applying heat.
Discussion Starter #6
Didn’t budge one bit, no rotating. There isn’t a nut on it though, it’s threaded into the carrier. I’m gonna grab a new bolt tonight, hopefully Nissan or Infiniti Dealer has one on hand. Fingers crossed for the heat. I think it’s also bound into the shock like you said, but I’d think it’d give a bit if that was the whole truth. I guess worst case I have to pound it out and I just get a nut to fit the other side if the threading doesn’t work anymore.
I use a 1/2" ratchet and a 6 foot jack handle on top of it. I have loosened things up to about 350 ft lbs of torque.
Discussion Starter #8
We broke a 1/2" 6-pt socket with a breaker bar with both my dad and I lifting. That's dad strength x2. Or is it squared because I am his kid but also a dad?
Anyway, easily 100K ft lbs with both of us. Didn't budge. I got a big ol' pipe to try tonight.
My guess is that you're going to break the bolt, or tear the threads right out of her.
Do you have a replacement nut/bolt? I just went to a hardware store and found a similar size diameter/length to fit. Since it's not a control arm or steering related bolt, Grade 8.8 or whatever they had, was good enough.
At this point I'd just cut the bajezus thing off.
Discussion Starter #10
Picked up 2 new ones at the dealer this morning in prep. I'm assuming the things gonna be buggered up. I'm just afraid of stripping the carrier when I get the bolt out. Part of me thinks that I could just replace it with a nut and bolt combo.
Discussion Starter #11
So the bolt came off with some good old fashioned elbow grease and massive torque from a 30” pipe.
However, the air line didn’t come out and eventually broke off in the valve. I put it back together; it’s drivers side so easy enough to fix it seems. However, I want to disable the compressor until I fix it, maybe even during warmer weather... that should be fine, right? I’m assuming maybe a fuse or something to pull somewhere?
Feeling the same pain right now. Rounded the nut with too much torque and now I'm trying a nut extractor to no avail.
Also struggling with the air line and feel like I must be doing something wrong. Anyone got advice for a newbie here?
Discussion Starter #13
I ended up breaking the air line. I stripped it and inserted it like stripping a wire and reinserting. It's working fine.
1 - 13 of 13 Posts
