A few pictures of the bike fork mount roof rack. I have always used fork mount set-ups but as many of you know the Armada rack can be difficult to configure because of the span. I used Rocky Mounts Noose fork mounts that install directly to the factory load bar. I like the set-up and the quality of the product. The beauty is that is does not require the roof rack extension kit. The wheel trays are 45 inches and hang over 3-4 inches off the back load bar. It is a perfect fit. If you do go with this set-up make sure you go with the Noose slx which has slightly longer trays than the Noose SL.
http://www.cardomain.com/id/seoffroad1
