I've had a lot of owners ask me where I used a heat gun to melt the tirewell to get my tires to stop rubbing. Here's a pic I put together. Circled areas show the areas I had to heat up on both sides with a heat gun. I then depressed them using a screwdriver handle until they cooled. This got them out of the way enough to stop the rubbing. Not much more room as there is steel behind the plastic in one spot. It would have to be bent or cut to gain more space.
:chainsaw: :teeth:
:chainsaw: :teeth:
