third row seatbelt anchors
I'm not sure if I'm missing covers or not. Where the third row outside seatbelts anchor to the wheelwell is there suppose to be a protective cover? Mine has a plastic cap over the bolt and that's it. The reason I ask is that I hauled a couple sheets of plywood home the other day (only about 2 miles) and the plywood really chewed on one of the seatbelts just above the anchor bolt. If I'd of had to go more that a few miles I'm sure it would of damaged it enough that it would of needed to be replaced.
It sure seems to me that there should be a shroud on them up 2-3" above the anchor to protect them?
Don't think a cover is standard on the truck.
Cheap fix - just hit your local parts place for a six to twelve inch velcro fastened seatbelt cover - normally neoprene or maybe faux-sheepskin.
I figured out today that the second row lower anchor covers work on the third row as well. Though a minor detail it does look much more finished plus it protects the belt where it wraps though the anchor. This is the area that got buggered up when I hauled the plywood home.
I have an email into GregV to see if he can get me a set with my microfilter order. I can't find them listed on any of the parts sights though?
Discussion Starter · #4 ·
Check out this picture, did anyone get these covers for the third row lower anchors (Part No. 86628)? Mine are just plastic caps over the bolts. :huh:
