1 - 1 of 1 Posts
Here's a link to the video I made on replacing the shifter control module. If you can't shift into reverse from neutral, or out of park, it may be your Bessie light switch or shifter control module. If your brake lights aren't coming on, go after the brake light switch. If the brake lights are coming on but you still can't shift out of park or into reverse, then go after the shifter control module. Here's the link shifter control module video
1 - 1 of 1 Posts
