It took all of 10 minutes (per light) to install my new Sylvania Silverstar lightbulbs. I just did the low beams (9006ST...40 bucks from Pep Boys).
Here is the play-by-play:
1) Turn the wheel all the way to one side so you'll have room to operate. I started with the drivers side, so i turned the wheel all the way to the RIGHT.
2) Remove the one screw thats located in that one recessed area, then remove the one clip that sits up top near the edge of the fender...pull the fender well lining back to gain access to the bulb area
3)Undo wire connector to the bulb, turn the bulb about 1/4 turn counter clockwise and pull the bulb out.
4) insert Silverstar bulb and follow the steps in reverse.
5) PIECE OF CAKE! You're done!
I've had Silverstars in my Mitsubishi Eclipse for about 3 years now and I love them...they've never burned out out or caused me any problems. Don't know why its taken me this long to put them in the Armada. Although I did the installation without touching the actual bulb I did where those latex shop gloves just to be on the safe side.
COME ONE NITE TIME SO I CAN TRY THEM OUT!!
