· Registered
· Registered
Today I removed the white cover (it has sticky stuff and can reattach it later). You can probably work with it but it gets int he way in my opinion so I took it off.
About the plastic cover, just pull gently. I was able to take it off without breaking any pins.
Installing the new handle was a pain, the old one had plastic (or silicon maybe?) stuck in one of the bolts so it was hard. Once all the cable were disconnected, I had to wiggle it to from the inside in a certain way and finally it got out.
Anyways, I installed the new handle I'll open a new thread about the back camera since it doesn't fit quite right but the view is the same as in the past so I'll try to fix the gap to avoid rain getting in.
Cheers to all the peeps that supported on this and other threads where I asked questions.
BONUS: fix of the back window not opening
I was able to fix the the hatch window (it has to be open to remove the back cover). You can probably change the hatch handle without removing the back cover but it was easier to have it out of the way.
Sky Vehicle Motor vehicle Automotive tail & brake light Car
It's really simple to fix. See the left pink connector?
Hood Automotive design Eyewear Vehicle door Automotive exterior
You just need to put the cable inside (like the right one).
Product Textile Seat belt Car seat Vehicle door
And the hatch handle for the window will work.
