My brakes have started squealing when the brakes are applied at low speeds. Anybody else? I have had the brake fix done.
Still squeaking. Since then, I've had the "final-final" brake fix done (at the time of the posting, I only had the first final done), so the brake dust is reduced, no juddering yet, but still got the squeak.logdog said:I just noticed the same thing over the weekend - a loud high pitched squeal when the brakes are applied. It's just started so I don't have much to go off of yet. I had the permanent brake fix done about a month ago - I'll have to look at mileage etc since the fix. But it appears to be something that only happens once or twice when I first start driving the car. After a few stops I don't hear it anymore. Is that the same thing you're seeing?
Armadaof1 - This is the first post I know of where the brake judder has returned after the Nissan fix. Are you sure you have the final brake fix?Armadaof1 said:My brakes continue to squeal. I had the final brake fix over 10k ago and three trips back to the dealership have not fixed the squeal. I also tried the CRC Anti-Squeal and it made little to no difference. Later found that it isn't recommended for shimmed pads (which ours are) despite posts at Titan Talk that says otherwise.
I'm headed back next week for return of the dreaded brake judder and the brake squeal will again be on the list of complaints.
