1 - 15 of 15 Posts
I’ve had a number of people reach out to me about Old Man Emu Patrol spring's, so I figured it was time to create a proper “build thread” for my Y62 Armada.
I’ll start with the lift install. This is not the easiest install in the world. As such, I did not take a ton of pictures because I was busy wrenching and swearing, but I will do my best to explain how I did it. I have access to a full shop which made this a bit easier, but you could do this in your driveway with the right tools. Also, I legitimately needed three people at points so bribe some friends to come help. If people have insight on how to do this smarter, easier; please pipe up. I could not find any instructions or build threads out there that documented the whole process before I started, just bits of information here and there that I pieced together. I’m hoping that this will help the next guy that comes along.
First, the parts list (All Old Man Emu parts were purchased from Cruiser Outfitters):
Front:
Springs: OME 2978
Struts: OME 90015 x2
Upper Control Arms: SPC 25560
Sway Bar: PRG Replacement End Links and Bushing Kit
Camber/Toe Adjustment Bolts: SPC 87520 (two kits, one per side)
Rear
Springs: OME 2986
Shocks OME 60084 x2
Camber/Toe Adjustment Bolts: SPC 87520 (modified, explained below) AND a 14mm x 2.0 thread die.
_
Rear Suspension
First, obviously, jack up and support the vehicle on the frame then remove the rear tire of the side you will be working on. You will want to leave the other three tires on and touching the ground (This is because you need the weight of the vehicle to help you get the new spring into place).
Then disconnect the air compressor. You can either just cap the weather pack and air lines or remove the compressor and associated hardware all together, your choice.
Next remove the air line from the shock. You do this by pushing the red ring towards the shock body with a flathead screwdriver, then pulling the air line out. This will cause a rush of air as the shock deflates.
Remove the top and bottom bolts from the shock and remove it from the vehicle.
Now, unclip the ABS wire from the spring bucket as well as the air suspension height sensor. Support the underside of the spring bucket with a floor jack and remove the inner bolt from the bucket (#2 in the diagram). You do this for two reason, this is also the toe adjustment bolt which you will be replacing with a modified SPC 87520 and because when you are putting the new spring in, this is the straightest angle to get it into place.:
Slowly lower the jack until the spring is free and pull it out.
At this point, you should take the set of SPC 87520 camber bolts that you have for the rear toe adjustment and using the thread die, cut another ~1/2” of thread onto the bolt. Then, leaving the die on the bolt, shorten the bolt by a corresponding 1/2", file the nose down so its tapered a bit, and back the die out to clean up the threads.
This is where shiz gets real! The OME 2986 spring is about 4.5” longer than the stock spring (results will vary here depending on how worn your springs are) and has 2mm thicker bar. There is no way that we could find to get the new spring into place without compressing it about 3”. At this point, I feel obligated to say that is you are in any way uncomfortable with compressing a coil spring that much, I don’t blame you. Take the vehicle to a shop and have them install the lift.
We had a center pull style spring compressor (like this), though we had to modify it to be long enough by using a threaded bolt off of a pull hammer. We installed it with the spring sitting in the bucket and a flat steel plate under the bucket. Then we cranked on that sucker until it fit, like I said about 3” of compression was needed.
Once you can line the spring up with the upper bucket, put a floor jack underneath and slowly jack it up until you can put in the new toe alignment bolt. (You will start to lift the whole vehicle when you do this. That is why you need the other three wheels on the ground so you are using the weight of the vehicle to your advantage). Tighten that up and remove the jack and spring compressor.
Then install the new shock, which is just the reverse of removing it.
Put the wheel back on, and with the tire still in the air use the toe and camber adjustments to eyeball the wheel as straight as you can. Then tighten all the bolts up to spec.
Repeat on the other side.
Front Suspension:
Jack up the front end, support the vehicle on the frame and remove the wheels.
You will first need to remove the old strut assemblies. This is simply taking out the bottom bolt and the three nuts on the top. Once everything is loose, it should just pull out.
Now, dismantle the old strut, pull the top plate off, and then using that with the OME parts, assemble the new strut. You’ll need a way to compress the spring to do this, again you can rent compressors or you can just have a shop build them for you.
Next, you basically have to dismantle the rest of the front end. You’ll need to remove the steering knuckle (I hung the knuckle from the frame so I didn’t disconnect any brake lines):
The sway bar:
And the upper and lower control arms:
Once you have done that, take your new SPC 25560 upper control arms and mock them up in place. Let the arm hit the upper strut tower and mark where it hits and then using your preferred tool, notch the tower so the UCA has maximum range of motion.
(Photo’s courtesy of leeleatherwood because his are way sharper than the ones I took.)
Remove the mocked up UCA.
Reinstall the lower control arm using the new SPC 87520 camber bolts. Leave the LCA loose for when you install the new strut.
Put the new strut into the upper strut tower and loosely reinstall the nuts. Then pull down on the LCA so you can fit the lower eye of the strut into place and install the bolt. Snug both the upper nuts and lower bolt.
Next install the new upper control arm. Follow the instructions from SPC for installing the ball joint. I installed mine as far back in the UCA as I could with them pointing forward, allowing for +0.5* greater camber and caster adjustment. Leave the UCA loose until you reinstall the steering knuckle.
Reinstall the steering knuckle and tighten everything to spec.
Put a floor jack under the LCA and use that to help align the steering knuckle with the upper ball joint. Once that is connected, then reconnect the tie rod and tighten both to spec.
Reinstall the wheels and put the vehicle on the ground. Now, replace the end links and bushings on the sway bar with the new ones and reinstall it on the vehicle.
Jack vehicle back up, eyeball the camber and toe as best you can and tighten everything to spec.
Now, get it aligned! You will have to sacrifice some rear camber to get the toe in spec, but that’s OK.
And you’re done!
Spare Tire:
I’ve read in a couple places that you can’t fit a 35” tire in the factory spare location, this is incorrect. You can indeed fit a 35” tire there easily.
Discussion Starter · #2 · (Edited)
Skid Plates
I already have a post about this, but I figured I’d consolidate it here as well.
I purchased a set of DASH Offroad skid plates from Nisstec. These are for the Patrol, which means that it is just the three plate kit for the oil pan, transmission, and transfercase. It excludes the radiator skid plate, as the Armada has a longer nose. They are developing a radiator plate, but no ETA on that. The guys at Nisstec in Denver were great to deal with and I’m super happy that they are beginning to bring in more DASH products. The kit came with no instructions, which is fine; they’re just skid plates. But I figured I do a short write up on how I installed them just in case anyone is looking for a little guidance in the future.
1. Unboxed everything. Three skid plates (obviously):
And a package of fasteners:
In the fastener package I had the following:
Bolts:
Two (2) M10 x 1.25 hex head
Five (5) M10 x 1.25 Allen head
Three (3) M8 x 1.25 Allen head (long)
Two (2) M8 x 1.25 Allen Head (medium)
Four (4) M8 x 1.25 Allen head (short)
Studs:
Four (4) M10 x 1.25 | M8 x1.25
Nuts:
Six (6) M10 x 1.25 hex nuts
Three (3) M10 x 1.25 captured nuts
Six (6) M8 x 1.25 rivnuts
Fish Rods (or whatever they’re called):
Two (2) long
One (1) short
2. Next, I lined up all the skid plate in order under the vehicle and make note of where the rivnuts will need to be installed. There are four holes on the cross brace behind the oil pan and two on the cross brace in front of the transfer case.
(As a note, to install the rivnuts you will need an installation tool like this: RZX 8” Rivet NUT Gun)
For the two in front of the transfer case, I had to mark the location and drill holes. Since mine is a fairly early build date ’17 Armada, not sure if this will be the case for everyone. All the other holes lined up perfectly.
3. Next, I fished in the captured nuts. The two longer fish rods go in the cross brace in front of the transfer case. I fished them in from the sides, but there may be other ways.
The short one went in the very back. I forgot to grab a picture of that, but it’s pretty obvious.
4. Install the studs in the cross brace behind the oil pan.
5. Install the bracket at the rear. Again, I forgot to get a picture of it installed, but its obvious:
My only note on this is that the threaded hole that is already part of the vehicle was an M10 x 1.50, not an M10 x 1.25. So I had to source my own bolt for that.
6. Install the skid plates rear to front. The reason for this is that you want the front lip of each plate to be covered by the plate ahead of it so if you do slide these over a rock, the lip doesn’t catch.
7. Tightened them all up, and it looks pretty slick!
This is never going to be a rockcrawler, but it sure feels better to have these on there protecting all the sensitive stuff underneath.
___
Rock Sliders:
No one in the US makes or carries rock sliders for the Y62 platform, so I snagged a set of Trail Gear Tacoma DC sliders. They are 78" long, and the Armada is 80" between wheel wells, so not a big deal if there is an inch gap on either end. Since my welding skills are pretty weak sauce, I took them to a buddy to modify them a bit and mocked them up:
After we were satisfied with how they fit, I got them powdercoated a textured black. Then it was just welding them on. They turned out great!
2019 Armada SL
Great writeup, thanks for putting the time to do so! Do you have any overall completed pics?
Discussion Starter · #4 ·
Its been raining here, so no, not yet. Once ther weather clears up I'll share some poser shots.
Now that it's stopped raining, here are some post lift parking lot photo's:
Note the front is sitting higher than the rear, this is because I put on the medium rate springs in anticipation of putting a DASH Predator Bar and winch on this summer. That additional weight should weigh it down enough to even everything out.
Here you can see the positive camber I had to use to get the toe straight. There are some camber bushings you can get from OnTrack 4x4 in Australia that can fix this, but I'm thinking I'll try another set of the SPC 87520 camber bolts and see if that'll help.
2019 Armada SL
Dayum, that's huge! Looks great!
Discussion Starter · #8 ·
Have you been able to get the Camber corrected in the front and rear with the aftermarket camber bolts?
No, using the SPC 87520 bolts for rear camber did not offer enough adjustment. I have a set of SuperPro SPF4131K bushings coming in from Australia. These should allow me to get the toe in spec without having to sacrifice camber. I also have an inquiry into OnTrack4x4 regarding a camber bushing kit they supposedly sell (Roadsafe S0535U-KIT), but I haven't heard back yet.
Which control arm are you going to put the Super Pro’s in? The kit comes with (2) so will that do both sides or did you have to order 2 kits?
Discussion Starter · #10 ·
The SPF4131K's are for toe adjustment, so they go in the rear arm, or spring bucket (where bolt #2 goes here):
OnTrack sells a different camber bushing kit for the LCA (Roadsafe S0535U-KIT), and that replaces both inboard bushings you see here:
That makes perfect sense now.
The SuperPros should pull back the lower coil bucket arm, being that they are double offset, setting the new toe angle by pulling it outwards if my geometry is correct. The on Roadsafe bushings are probably double offset too and will give you just enough adjustment to push out that front lower control arm enough to bring the camber back to near 0/-1
I do wonder now if an adjustable UCA for the rear would give you that camber back with more range, eliminating the need for the roadsafe bushings. If anyones ever tried removing an OEM bushing, they know the struggle will be real when they try to install the replacements.
Discussion Starter · #12 ·
You want to push the spring bucket (rear of the tire) out, so the offset will actually be to the inboard side of the bucket:
I'd imagine that being able to put in an adjustable ball joint would give you a lot more camber angle just like the front; but thats above my skill level for figuring out all the geometry involved to get that right. Removing OEM bushing can be a pain, but these LCA's and Spring bucket are pretty easy to just completely remove from the vehicle; you can just use a press to remove and install the bushings. Or take them to a shop once they're out. Short of that, burning out bushings works like a charm, even if it smells like, well, burning rubber. ;)
Discussion Starter · #14 ·
Have had a busy work/life schedule over the past few months but finally had some time yesterday to take the Armada out on a post lift shakedown cruise. Everything worked great, rode surprisingly well on the washboard roads. I really thought that after replacing the air shocks in the rear it would be a much rougher ride, but it was still quite supple. Had a couple spots where I got a wheel off the ground (no pictures, sorry) and the traction control is still working great. I was a bit worried that the added weight of 35's would affect that negatively, glad it didn't.
I do have a slight, intermittent click/pop coming from the left front. Couldn't see anything obvious but I need to do some diagnosis on that, but it hasn't affected the drivability at all.
Still need to get my camber sorted. Hopefully the SuperPro eccentric bushings solve that, should be able to get those installed in the next week or so.
1 - 15 of 15 Posts
