Stock grill removal
6149 Views 7 Replies 7 Participants Last post by  TanK1
Does anyone have some advice or pics on how to remove the upper grill assembly. I have someone interested in doing a grill swap with me, and I was wondering what is all involved. I'm sure I can figure it out, but I would like some advice/input from those who have done it already.
Thanks,
1 - 8 of 8 Posts
The attached drawing may be of help. Notice the square heads on the plastic retainers. They have a screwdriver slot. Use a screwdriver to rotate the heads about 45 degrees, they will then line up with the hole in the clip and you pull forward to release it.
See less See more
Thanks, that is a big help.
Be patient, take your time, and work carefully. It took me about 2 hours to do top and bottom grills with documentation provided from the new grill.
Its super easy bro . You'll have no prob removing it . And re-installing it only takes about 5 mins. Just turn the tabs like a 1/4 turn counter clockwise scr38 said and it will pop right off. Then remove the tabs from truck and put them on the grille line up the holes and just pop it back on . It's cake ! Good luck !
had to remove the grille tonight for a second time (first time was way back when i installed a new grille... it WAS cake to reinstall) and had a hell of a time putting it back on. i lost 3 clips. i remember it was easy when i first did it but this time around i was lost. so i need to grab some from the dealer. does anyone know the correct name for these jokers and the cost?
marctronixx said:
hso i need to grab some from the dealer. does anyone know the correct name for these jokers and the cost?
I couldn't tell you the name but the part number is 76882-0M060
LOL, Nissan just have them listed as clip. About $2.50 each.
Nice Datsun Bre!
1 - 8 of 8 Posts
