1 - 3 of 3 Posts
Hello everyone, I was just wondering if anyone have noticed strange tire wear on their vehicle. I have a 2005 LE 4wd and noticed some slight , maybe feathering on the right front tire. Also some on the left front, but not as much as the right side. It has less than 4500 miles on it. I am going to have the allignment checked this weekend. Can it be just normal tire wear? Is it happenig from decellaration on turns or accelaration? Am I being too darn picky?
For the people who dealt with brake judder, did you notice any type of tire wear other than the ordinary?
I would appreciate any input. I am just concerned. Thank you.
Probably alignment. Many people say their factory setting were off. ;)
tire wear
These are heavy 5000 lbs+ trucks and uneven tire wear is normal to some degree if you go beyond 3500 between rotating. If you have gone 4500 miles with out rotating, your front tires will certainly feather or cup. 3500-4000 should be max before rotating a truck/tire this size. What you are experiencing is not unique to the Armada, it is common in any truck this size.
1 - 3 of 3 Posts
