1 - 15 of 15 Posts
we use to have a suspension squeek type of noise coming from the front...we took it to the dealer and he said it might have been caused b/c of a car wash (water) and the water froze (it was winter) and that's the cause of the suspension squeek from the front...pretty sure the dealer was lying b/c the squeek barely went away...the squeek only happened when it was really cold though...just go and ask ur dealer
fstrom said:
Does anyone elses suspension creak or squeek?
From where? I had a squeek from the rear. Turns out there was a TSB on the rear hubs needing greasing. No more squeek. :D
Mine comes from the front for sure. Haven't heard it since the spring. Usually detected going slow with the windows down over speed bumps in parking lots, especially when crossing them at a slight angle.
Mine was different. Like a metal clink ting noise that happened when you started applying gas from a complete stop.
excatly same with mine..only in winter though
I have the same problem it start when I got the brake fix "final one" I am to busy to take my mada to the dealer... :(
Takes a little time to do. They need to install new seals or something when they do it. They ordered the parts for mine and I dropped it off for a couple hours. ;)
I had this problem. Squeaks from front suspension when turning and going up my driveway. Dealer confirmed this squeak and fixed it. They told me the bushings were worn out. At about 8 or 9 thousand miles. I don’t think so. Whatever!
I have been fighting a creaking/cracking noise in the front end of my Armada for over a year. The dealer finally found the source of the noise. It was really two problems. They found excessive play in both outer sway bar links. The sway bar bushings were split and would not stay in the retainers. They replaced the sway bar links and bushings. The second noise (cracking/creaking when pulling into the driveway) was found by using 'chasis ears'. They stated the lower control arm bushings were binding against the frame. They remove the control arm and lubed the bushings, reposition the control arm. I am not to happy that it took over a year to find this, but happy the dealer stuck with it. I am noise free now in the front end of the vehicle. I hope this helps someone else in diagnosing their problem. :D
never had this problem, but I'm Glad they fixed it for you :2cool:
Glad to hear you have got it licked..I am going to my dealer tomorrow for the same thing..thanks to youse guys..I am gonna print this thread and tell them ...here's the problem! Thanks again.
Good idea! Might do the same when I have mine checked on Tuesday.
I have the same problem and gonna print this thread too..
Thanx all
1 - 15 of 15 Posts
