Swapping to LED's High beams and for the interior - 2020 Armada
1313 Views 3 Replies 3 Participants Last post by  Silversolid
Started out with the high beams. Why they come with halogens is baffling to me. I used the Sealight X2 H11's https://www.amazon.com/gp/product/B09KCDFV6Y/
Stuck the ballast box on a flat section on the back of the headlight housings. These are fairly easy to reach and replace without removing anything. I like the matching look much better and it is much better light also. Though I do not use my brights often where I live.
Automotive parking light Car Land vehicle Vehicle Motor vehicle
Next up was the reverse and license plate lights. These were pretty easy. Popping out the license plate light housings and then switching the bulbs. I bought a 10 pack of the 194 (W5W) bulbs and a set of 921 (W16W).
Hand Photograph Blue Finger Gesture
The reverse lights are easy to get to. Just pop a panel off the inside of the lift gate and there it is.
Automotive parking light Car Automotive tail & brake light Vehicle Automotive lighting
The same 194 are used in the door panel illumination lights. They just popped out with a plastic pry tool. Then the lens has to be carefully removed to access the bulbs. Also see here are the footwell lights. These are tiny bulbs!!
Ended up figuring out what they were and ordered a pack.
Product Material property Font Jewellery Fashion accessory
The footwell bulbs are size 74. Found a 10 pack here https://www.amazon.com/gp/product/B08RJH2VMY The other ones didnt seem to matter, but these you have a polarity so make sure they turn on before putting it all back together.
Product Finger Automotive tire Gesture Thumb
Last was the rear dome light. The front ones looked decently white to me from the factory, but this rear dome in back was dim and yellow. https://www.amazon.com/gp/product/B083ZL9RB4/
Hood Automotive design Personal luxury car Automotive exterior Gas
Automotive lighting Gas Fixture Glass Automotive exterior
Automotive lighting Fluid Gas Auto part Vehicle
See less See more
8
Reactions: 5
very good post with both images and links. I just wasted $35 getting OEM footwell ones about 5 months ago. Thanks again.
You are welcome. I have been doing this for my main vehicle on another forum. This is the stuff and the way I like to post. For some reason, many dont. Visual is always better.
Reactions: 1
many thanks for this great write up with pics. Wish i had seen this before starting my replacement journey, would have certainly cut some guess workout.
i wonder if we can write up the footwells to remain on with the ignition or when the interior lights are on... would provide for some nice ambient lighting.
