My back hatch rattles badly at times, anyone run into this? Or does this felt tape thing I see posted for the front doors work? Any ideas would be greatly appreciated.
What year is it? Is it the glass or the door that rattles? Have you shown the dealer? They fixed all the rattles I know of for '05 and I am rattle free. They also can fix the '04s as well.mac daddy ride said:My back hatch rattles badly at times, anyone run into this? Or does this felt tape thing I see posted for the front doors work? Any ideas would be greatly appreciated.
What exactly do you mean? I am still having rattling issues.I've had the same problem with rear lift gate, I assume my screws got loose from bass box in rear..You will have to pry up plastic strip and get a magnetic rod or screwdriver and put down in hole, there is a flat metal piece that you will have to patiently pull up,when you get it to the top try lining up hole and screw in one side of loop do not tigten as u might need to adjust for other hole,make sure latch is lined up by closing and opening and you should be ok
