I have a 2008 Armada the temperature gage will go up past the line for up to maybe 30 seconds or less then drop back down and be normal.
I have replaced the radiator, thermostat, and water pump. It has had air vacuumed out. It's still doing this after doing all of that. Any suggestions?
The thermostats have different temperature ratings make sure you get the right one my 2008 armada was doing the same thing but try that first because the thermostats May look the same but they have a different temperature rating hope it helps out
Did you install the thermostat correctly. There a small hole that needs to be pointing up to help bleed the system.
Automotive tire Rim Camera lens Audio equipment Door handle
