Can anyone advise on option for changing rear shocks , from air to regular also can I keep the springs I have?
Search Rear Air Delete. You would have to get stiffer springs if you did this. The springs alone don't support much weight and are meant to work in conjunction with air shocks...the Armada will often sag when the rear air fails due to this fact. Well worth it to do this upgrade!
like this ?
That's a technique. The consensus is Moog Springs and Bilstein Shocks. Search tool will give you the part numbers.
