I have had the vehicle now for 6 weeks and have come across my first nail in the tire. I noticed the nail before the monitor system, to which it alarted me a few minutes later due to a drop in preasure. I had the nail pulled and plugged to which it is showing me a low tire (even though all are at 35 psi). Anyone else with a similar problem with a possible fix?
Other than this, I have had no problems other than excessive brake dust accumulation.
Thanks,
Jason Boeckers
Only one run-in with the tire pressure monitors. When my tires were rotated, the bubbas reset the pressure on all four to 32psi. Next morning, tire press warning sang out. Filled tires to 35psi and the warning light reset itself within 5 minutes.
i am not sure what to do in this case, but i noticed that my Armada is supposed to have this LED on the back of the steering wheel or column, is that where it is located and do all Armada's come with this monitor as standard? :confused:
Tire Pressure Indicator
The low tire pressure indicator is on the left side of the instrument cluster. You will see it (as well as all others) when you turn on the ignition, before starting. (Check your owners manual)
