Tire Pressure
2087 Views 6 Replies 5 Participants Last post by  Andrew
Can some please advise me what the correct tire pressure for my Armada?
1 - 7 of 7 Posts
Its in the manual. 35lbs is about right. ;)
For stock tires, you want to stay around 35lbs. I used to run 40lbs the truck felt very bouncy. Conti. tires sucks !!!
If you tow, make sure you increase tire pressure. Also, be sure to check and adjust after the tires have sat for a while (cool).
Andrew
thanks everyone for the advice on the tires. I did check my handbook, but it advises me to look under the lid of the central console glove pocket! But no details there? I guess it is because I am living in Kuwait.
Door Jam
Try the sticker on the driver's side door jam.
Tire Valve
When I was checking the tire pressures, one of the valves just simply broke in half!!! It was as soft as butter.
So I ended up with a flat and had to change my wheel, so now I have to go and get the tire monitoring system all reset and a new tire, all because I just checked the tire pressure! :confused:
1 - 7 of 7 Posts
