1 - 9 of 9 Posts
Greetings all. Brand new to the forum. Looking at 2020 Armada Platinum and have no idea what equipment I need to pull a 7000 lb rv.
Can anyone point me to a link for brake controller, harness, tran cooler, etc.? The Platinum apparently has no towing package. Thanks!
Platinum has towing package built-in I believe and you can tow up to 8500lbs. You do need to install a brake controller though
Yup. Everything is built / included except for the brake controller. For that, follow the obd2 wire under the dash about 6" to a taped white plug along that harness. Plug in your adapter then controller.
I just towed an open car trailer loaded today loaded to about 5k. Easy peasy. The reviews about a bit of sway is the hydraulic suspension doing its thing. It takes a split second after a steering input to stiffen up and it feels like a wobble but it's not.
Here is a youtube video of it towing 8k over the Ike.
I suggest you monitor your transmission Temp. when towing,when pulling grades or stop & go traffic. I use an App from OBD fusion on my phone. Search for OBD fusion on this site or go to their web site.
Since we have transmission heaters and coolers what is the range to look for?
I found average low Temp. when towing to be 187 degrees. The high Temp I become concerned is 210 degrees when towing on 6 percent grades. A Temp above 220/225 degrees will reduce the life of some parts. If ever a high Temp is continued for many miles I would have the Tranny oil replaced as soon as possible.
Per the service Manual,
• When A/T fluid temperature rises [to approximately 100°C
(212°F)], bypass valve closes and allows ATF to flow into cooler
core. ATF flowing into cooler core is cooled by air stream caused
by vehicle travel and returned to transmission.
The cooler doesn't even open until 212°F, meaning 212 should be no problem. I expect it to get there quick but be very difficult to go above 225°F. I'll make a thread on my annual Nebraska trip where I end up towing over the Ike gauntlet.
Look forward to your information on the trip. How are you monitoring the Temp while towing ?
Note these guys were not using a weight distribution hitch, yet they complain about the rear end wiggling a bit when the vehicle goes over a bum. What they did there was pretty irresponsible.
1 - 9 of 9 Posts
