I have a 2006 Armada SE. I did not get the tow package. I installed an OEM hitch. It came with the 2 of the required relays and the plug that the wiring harness plugs into. I connected up to the trailer and checked out the lights. I do not have running lamps. I have 12V, flashers, stops lights and both blinkers.
I originally connected up and had no right blinkers, this is when I discovered that I needed the 3rd relay. So off to the dealer and installed the new relay. Got the blinkers, but still no running lamps. I looked in the owners manual and it doesn't even show the fuses. The fuse box doesn't have anything labeled as trailer anything.
So, anyone have suggestions as to what I can do? Anything else I can check to see that everything is connected? Is there possibly a wire that is not connected in a non-tow package SE?
Greg
Sorry, I didn't realize there was a Problems forum. If this would be better over there, a moderator can move it.
Greg
