Trailer wiring
2839 Views 6 Replies 6 Participants Last post by  BlakSpyda
Just got a postcard indicating the need to bring my 2004 in for a change in the trailer wiring harness for the armada. What problems gave rise to this, anyone know?
1 - 7 of 7 Posts
Apparently if there is faulty or in properly wired trailers a fire in the cab of the truck can result. Not good. Not sure how many have caught fire but I’m sure a few. I would imaging the conditions have to be just right. I can tell you one thing when I mounted my brake controller I noticed they use 14 gauge wire on the harness for the controller and what appears to be 14 for the charge wire to the rear 7 pin. This to me seems very thin for this application. I would always run atleat 12 but prefer 10 with either a 20 or 30 Amp fuse.
I too thought the charge line was much too small. I replaced it with 10 with a 30 amp fuse.
Ken
The factory fuse is 30 amps, so I am sure the factory wire size is OK for that much current.
Wire
Just because it is a 30 Amp fuse one should not assume all is ok. Notices were sent out due to a possibility of fire if there is faulty wiring on the trailer. That alone sounds like wiring that is not properly fused in the tow vehicle. The charge line is not 10g which is 30 amp wire, it is 14 gauge. The brake wire should be 12 gauge and it is 14 as well. This wire is without question over fused being 14 gauge with a 30 Amp fuse.
tires
Hey, it seems you might be trailering with your Armada, and just wanted to let you know we were informed that the tires Nissan put on the Armada aren't rated to tow the 9100lbs Nissan says they can. I have spoken to Nissan, Continental Tires and National Trans. Board.
Continental came right out and said, "No, they're not what you need", NHTSA is investigating the report and of course Nissan says "no Problem". We were advised to call Nissan and NHTSA and open claims so that if this goes any further we have documentation of the issue. Here are the numbers. Nissan 1-800-nissan1, NHTSA is 1-888-327-4236 and Continental Tires 1-800-847-3349.
That's good to know. Thanks! Even though I have changed my wheels and tires, I still have the originals and hopefully some type of recall or replacement will happen.
1 - 7 of 7 Posts
