1 - 11 of 11 Posts
So my Armada SE 2009 with Big Tow Package transmission started overheating recently while idle. If I am driving along, no issues. But if I sit with the truck on for about 10mins... the gauge goes up, all the way to the little mark on the right hand side. But a quick drive around the parking lot while waiting for the wife, and it goes away quickly.
Any ideas? SUV just turned 100k. I did the transmission partial oil change at 80k. We drive it less than 6k a year, as we only use it to tow the boat.
Thanks in advance!
-Alex
Assume you've checked the fluid to make sure it's full? I know you said you just did a change, so should be, but you might have a slow leak somewhere, or you may not have gotten it completely full when you did that. Also, do you see a change in engine temperature as well, or is that staying okay? Wondering if your coolant is low. But, both that and a bad clutch fan would have an impact on engine temperature as well as trans temperature.
So it's currently at the dealership now they change my condenser fan so far my coolant and thermostat is new I haven't done the fluid yet for the transmission but the engine does not overheat only the transmission
1 - 11 of 11 Posts
