1 - 13 of 13 Posts
I’ve seen people say that yes it does but I’ve also seen more saying it’s Pathfinder/Frontier only.
We are looking into Armadas for towing a small travel trailer and transmission issues are obviously something that would concern me.
Do you mean the problem where the tranny cooler line runs into it's own cooler/warmer section in the bottom of the radiator and sometimes the barrier between the engine coolant section and the tranny coolant section cracks and the two fluid mix? Yes - that sometimes occurs because of the basic design of it. I wouldn't say it occurs often enough to scare anyone away from ownership or towing - but it is physically possible.
Easy preventative fix costs under $100 and takes under an hour to plumb in an external cooler. Or get an aftermarket radiator.
Reactions: tchjts1
I agree with Staple's statement. I had a radiator issue on my '07 where it was leaking around the bottom, but the coolant never mixed with any other fluids. Replaced with a Koyo radiator and have been fine ever since.
I would be more concerned about the cracked exhaust manifolds issue.
Cracked manifolds are annoying but benign; they won't destroy your automatic transmission.
OP, don't let the radiator be the deciding factor in buying/not buying the Armada you're looking at. As previously mentioned, it's very easy to bypass the internal heat exchanger that brings the ATF up to operating temp. You can install an aftermarket unit, or (more likely) the vehicle you're looking at already has an external cooler, any you can buy $15 worth of 3/8" pressure hose, and run the bypass lines yourself.... it takes like 20 minutes, and a single beer.
There was no correlation of such intended. 2 separate things, but something to definitely be aware of.
I would categorize cracked manifolds as a bit more than annoying as the repair cost is north of $2,000 in most cases.
The point is that you can leave cracked manifolds alone, and nothing bad will happen, other than personal annoyance.
Not addressing a radiator that is internally leaking into the ATF system is going to be an issue.
We can agree to disagree on this one, Dan. The bigger picture is cracked manifolds = no safety inspection sticker in the window in my state. It is basically a forced repair in order to drive legally and without the chance of being fined, should you be pulled over.
Hey Staplebox, I am looking at doing this with my '12 armada (I was one of those with coolant mixing in the tranny with my old '06). Do you know of any specific parts for the under $100 fix? I was looking at spending a couple hundred on an external tranny cooler. I'd rather $100 if I can and its good :)
thanks
I used a Tru-Cool model similar to the one above, but can't find the model #. I believe it was about $75 and I also bought a length of this hose and these clamps. That's it.
I mounted mine in the lower grill opening on the passenger side, unlike in this video. I did not want to block the main radiator. Also the stock lines run to that lower pass side area already so easy to connect there. I'll see if I have a pic.
Same here for same reasons.
Good morning guys. Did you have something you followed for this installation? What are you mounting to on the bottom? I prefer the idea of mounting to the lower grill.
I found this this thread but this person drilled into the bumper of the truck to make it happen?
im happy to start a new thread if necessary.
1 - 13 of 13 Posts
