I pulled the brake calipers to apply some Disc Brake Quiet to eliminate squeals. When I did, I noticed on the passenger side that the inside pad was worn unevenly. Thick at the top and decreasing to about 2/3rds that thickness at the bottom. Still within limits for brake pads, but noticeably uneven.
Some quick background: I have the brake fix with new rotors and pads. The truck has been to the shop after this fix because it was pulling to the right under mild braking. This pull went away after a few weeks (possibly due to uneven pad wear?). No other brake problems and the squeal even went away.
