Volant Vulight LED Taillight
2625 Views 5 Replies 6 Participants Last post by  tlong
has anybody tried to put them on the mada.
http://www.premiertruckaccessories.com/vol12856900.html
they look good
It clearly will not fit, but then again, anything can be done with some or alot of bodywork! I think you can create the same effect by swapping out the Armada tail lights for the QX tail lights, but again that requires a little modification. This thread might help: http://www.clubarmada.com/forums/showthread.php?t=1520&highlight=tail+light
Check this out. QX56 taillights swapped
It's part of my to do list.
they look good
If they made one for the mada, they may have. That's a Titan one. Titans have beds in the back. Different entirely from the rear of the front door back. The QX fit, but they don't have reverse lights, and they don't fit perfectly, so you need to add some filler, and add reverse lights somewhere to make them work. Someone did this on this board. Looked good, but for $1000 of parts and labor, I'd rather spend the money elsewhere. ;)
QX56 taillights
I love LED taillights but not the ones off the QX. Doesn't look right with the chop shop reverse lights mounted under the bumper and Bondo/fiberglass in the gap below the lights. I'm am in the process of designing my own. It's not a rush project because I want them to look good. They'll have the same Armada Lens and I may make an all smoke lens to give it a different look, but it'll still have the back up lights. I'm at the point where I've got to dump some money into the project. I'd have to make about 10 sets to break even, so I'd have to get rid of them. Probably wouldn't be too hard on here if they looked good.
hey, well if you can do what you say, I can guarantee you that I will be one to buy. I really am looking to make my armada different.
