Warning light with exclaimation ! came on my armada. It is located at the lower left hand side of the dash board. Does anyone know what it means. I never received a manual with my new armada that I purchased in August.
Hi Lili, and welcome! That sounds like the low tire pressure warning light. With the tempratures dropping so does your tire pressure. Fill them up to the recommended factory pressure in the manual or the inside door way and it should go away on its own.Lili Clark said:Warning light with exclaimation ! came on my armada. It is located at the lower left hand side of the dash board. Does anyone know what it means. I never received a manual with my new armada that I purchased in August.
Your tire pressure is low. Shame on you.Lili Clark said:Warning light with exclaimation ! came on my armada. It is located at the lower left hand side of the dash board. Does anyone know what it means. I never received a manual with my new armada that I purchased in August.
Theya re collocated with the Valve stems or more acurately at the base of the stems inside the wheel. Most likely they are still on your stock rims. You should have had them moved over when you changed wheels and tires. I think they also have to be adjusted to match the pressure in your new gear as well. There are other posts on this topic.rp718 said:My light has come on before, but I've checked the pressure of all my tires only to find them all at 35psi.
Does anyone know where the pressure sensors are located?
I have aftermarket wheels and tires, so I may not even have the sensors anymore.
This happend to me when it got cold to. It only took a little air to get it to turn off. My tires were only a couple of pounds low.Lili Clark said:Warning light with exclaimation ! came on my armada. It is located at the lower left hand side of the dash board. Does anyone know what it means. I never received a manual with my new armada that I purchased in August.
