Where is the key located?
Can't find manual (too lazy to look), and dealer didn't inform me.
Marcellaus said:Where is the key located?
Worst case; if I can't find the key, who & how will I remove the wheel locks?Paisan said:Not sure but I'd et regular lugs as anytime I've ever seen them on a car they have been removed by theives (and myself) if about 30 seconds. It's a PITA if you have to take off your wheels and can't find it or it strips. Might as well go ahead and remove em when you can do it easily. Just get 4 lug nuts to replace em.
-mike
Any tire/wheel shop should have lug-removers. Basically they have a reverse thread that grabs the wheel locks and undoes them. We usually use a 19mm or size similar to the lug nut in a 12point socket and bang it on with a sledge hammer then just take it off and pop out the security lug nut. And then never use em again.Marcellaus said:Worst case; if I can't find the key, who & how will I remove the wheel locks?
