1 - 3 of 3 Posts
Hello
I recently purchased a 2020 Armada SL with auto leveling suspension to tow my 22’ TT (used with 44k miles and extended dealer warranty).
I recently noticed the rear looks like it is now sagging when unloaded and unhitched. I measured the ride height/wheelarch height and it seems really odd:
FRONT: driver 35” passenger 36”
REAR: driver 35” passenger 34”
I checked all the tire pressures.
Question 1: what is the factory recommended ride height/wheelarch height?
Question 2: is it normal for the drivers side of the car to be so different from the passenger side of the car?
Question 3: if I were to adjust the auto self lever under the car would it even help since there is still a 1” difference between the rear driver and rear passenger side?
Any other sights or suggestions?
Much appreciated!
2021 Armada Platinum Captain's Chairs 4X4, Aspen White Tricoat, Almond Leather.
Hi Santa Cruz Momma,
Did you find any more information on the uneven ride height?
I'm a newbie to the forum - just bought a 2021 Platinum 4x4 and measured the wheel arch heights:
  • Front is 36 inches (both sides)
  • Driver rear is 34 3/4 inches
  • Passenger rear is 35 1/4 inches
I haven't researched this very much, but find it curious that the heights are uneven - and yes, it's parked on level ground and unladen.
I'm interested in what the correct ride height should be, before I mess around any further. I think I saw a diagram somewhere in these forums that said 36 inches all around?
Any advice is welcome! Apologies in advance if this is a really obvious newbie question! 😅
Don.
So I managed to get this adjusted - mostly thanks to this forum. The adjustment is a little different in the 2021 - no threaded rod, but its easy to rotate the sensor slightly by loosening the nuts with a 10 mm wrench. Now sitting leve at 36 inches all around +/- 3/16 in.
1 - 3 of 3 Posts
