1 - 1 of 1 Posts
NTB05017
IF YOU CONFIRM A ticking noise at the front LH and/or front RH window with the window partially rolled down over rough/uneven roads or when the the door is closed and holding the glass stationary under the same condtions eliminates the noise. ACTION Order the required parts, in the Parts Information section, and perform the repair as stated in the Service Procedure. See this bulletin for further detail.
Found this TSB on the nissan site. I've seen some of you comment about window rattles when they are down part way.
1 - 1 of 1 Posts
