Has anyone upgraded their rear suspension from the auto leveling to something firmer such as OME or King shocks?
I want to upgrade my front shocks to something firmer to get rid of the floaty feeling. I was worried that if I upgrade the front shocks and don't upgrade the rears, it will cause issues. I believe most front shock upgrades (OME or King) will lift the front slightly.
Maybe call a few of the manufacturers as well.
I run airbags inside my rear coils on my 2018 and run them at a constant 10psi when unloaded. Firms the back end up perfectly. I'm in the Armada from over 10 years of previous pickup ownership, I prefer a firm rear suspension.
I originally purchased the airbags just to supplement the auto leveling system when towing, I haul a 28' camper. They help amazing under that load, but then I found that I like running them with 10psi all the time.
Good luck with the front end. I'd like to know what you end up with.
Discussion Starter #5
Which airbag setup did you use? Was it hard to install?
