Hey guys doing an engine swap on my late model 2012 qx56 with vk56vd and stumbled upon a difference between my stock motor and replacement motor which came from an early model 2014 qx56 the replacement motor has 4 cam sensors (2 on each side, one on upper inner cam, and one on lower outer cams aswell) and the original motor has only 2 cam sensors, I can’t find any info on this difference/change up online and everything else is the exact same down to a tee, am I supposed to just leave the 2 extra sensors on the lower outer cams unused and run the sensors on the upper inner cams as it is ran on stock motor? Anybody else came across this issue at all during motor swaps? If so what was the solution and outcome?
