Ok, I put gauges onto my ac system and have low low line pressure. As the result, AC comp won't start.
I did system self check and clutch apparently engages.
I can't add freon without comp engaging and sucking it in.
Anyone knows how to jump comp? I used to shorten pressure switch plug terminals but don't feel comfortable doing it on this car.
Thank you
I'm pretty sure I have seized comp.
I can't turn the center hub even with a pry bar.
I tried same on my ram truck and it spins easily.
I guess, that solves the question.
Thank you
