Status
Not open for further replies.
41 - 60 of 110 Posts
Discussion starter · #42 ·
Installed the snorkel today. Pretty easy install, hardest part really is getting all the og stuff out of fender well and the fender liner itself. She sounds really throaty now, can hear the air being forced into the snorkel. Think a nice K&N filter will pair nicely with this.
Still need to put the fender liner back, but that's a tomorrow's job.
she's getting there slowly.
That looks great - another unique addition. What does it look like under the hood?
Save
The install looks really clean! I gotta give you props for cutting the lower bumper / air dam + cutting the fender for the snorkel. Job well done - a beast in the making!
  • Love
Reactions: Mojo
Save
took the car out for a 400k drive today. Wanted to test the snorkel and suspension after they’ve been installed.
the drive is so nice now. The reduced swaying and leaning while moving this thing around is just so good.
A few pics -
No codes or errors to report.
It looks incredible. I am loving the ride height.
I received all dogs fox setup and was super excited till I installed rhe front suspension and the coils were not setup correctly for the declared 1.5" lift. It lowered my front end. Just disappointed 😞
Discussion starter · #50 ·
nah, you're good. They are adjustable.
How to adjust Fox Coilovers -
@Mojo Thank you very much. I will plan to do that.
Question: Did your Bilstein come height adjusted or did you also had to go thru this process?
I had to install rear suspension to determine correct height so i can adjust the front. Will do this tomorrow after buying the press.
Reactions: Randeep Dhillon
Save
My only hang up with the ADO kits is the Bilsteins are not rebuildable at all. The Fox 2.0s are rebuildable......but cost of rebuilding is almost the price of a new shock/strut per corner.
I'd still be looking to some of the other options out there for an Armada lift, especially since it is such a beefy land whale at 6k.
Iron Man can ship shocks from Australia, it's just a special order. Kings has a nice Y62 set, Dobinsons and OMEhave Y62 shocks also. Get Luso, King, OME or Dobinson springs for "standard height". Patrol sits almost 2 inches higher than the US Armada. Hence the springs for a "2 inch lift" from the Australian companies end up being closer to 4-5 inches and really wreck alignments.
Significantly beefier shocks, rebuildable (that makes financial sense) and better articulation.
Convenience is the main draw I could see from the ADO kit. It's not bad equipment, just better options exist.
Discussion starter · #58 ·
I'd love to see a Nissan Armada that has been beaten so much that it requires a shock rebuild. Let me know what abuse yours took prior to your rebuild.
Shocks are typically supposed to be rebuilt or replaced based on mileage, not just use and abuse.
To me, I'd prefer to have something that is rebuildable since it comes in at around the same price point.
The ADO kits are convenient, but imo not the best option for the money.
You're right. If there's a line of 100 Armadas, I bet one or two end-up with rebuildable shocks that actually get rebuilt. Maybe not the same for an AUS Patrol - those owners offroad quite a bit more. I'll upgrade my stock shocks one of these days but I really like the air-ride in the back and it's working very good for towing or extra load. Might just upgrade the fronts at some point in the near future.
Reactions: Mojo and primoV8
Save
Status
