Today while I was driving suddenly the BCI malfunction light came ON. I had to turn the engine off and fire it up again to make it go away. Anyone have this come up? Not sure why it popped up. Backup camera and sonar is functional.
My OEM lasted a month or so after I cleaned the contacts in the brake switch then started having issues...put my replacement switch in a couple weeks ago and all is well again. I took the OEM switch apart and cleaned the contacts again (black soot was on them again) put it back together and put it in the glovebox as a backup. Looks like it’s just going to be an ongoing issue but I’m out of warranty so at least I know what the problem is and I can fix it very easily.Any updates on any success stories? I am having the BCI and intermittent no start issues as well. Been in twice and have a brake switch and some module replace but still not fixed.
Hi- this is helpful. can you tell me where the brake switch is and how easy/ hard is it to get to?2019 SL 40,000 Miles car wouldn’t start intermittently over the last few weeks, yesterday BCI malfunction came on and VDC came on and the brakes locked down and engine lost power (both symptoms of the VDC when spinning tires) After reading the owners manual (to no avail) I came on this forum and followed several folks advice (thanks y’all). I topped off the brake fluid but that did nothing. I ordered a new brake switch yesterday from eBay $14. While I am waiting I decided to take the old switch apart and found it to have black soot (for lack of a better term) on the contacts inside the switch...cleaned them off applied new dielectric grease (added some to the plunger too for smooth operation) put it all back together and it still did the same thing...then I adjusted the switch to where the plunger did not touch the brake. Car started without pushing brake. So then I adjusted down so that the brake (when released) just pushed the plunger in about 1/16 to 1/12 of an inch. Got in and it cranked right up! Backed out and no VDC lights and no BCI malfunction (they were on continuously before) and brakes were released. Drove it around the block and it’s working as it should. My new brake light assembly will be here next week but I plan to keep this one in until it malfunctions again before I replace it with my spare. Hope this helps
It is located on the brake lever (above the peddle) it's not hard to get to but you will have to lay on your back to see under the dash and remove it. There are 2 sensors (BCI & Cruise Control) contacting the lever...the one on the top is the BCI and one you want to clean/replace. Just make sure you follow my instructions when you put it back in so that the plunger just barely pushes in 1/12 to 1/16 inch when the brake is fully released, otherwise it will engage the brakes and you won't be able to drive it (ask me how I know, lol). The one I replaced it with ($14 off ebay) has worked flawlessly since I installed it so I hope the problem is fixed.Hi- this is helpful. can you tell me where the brake switch is and how easy/ hard is it to get to?
OK perfect. I watched a youtube video as well on brake switch replacement. I don't have a new one, but I'll clean the contact points and see if that works. I may have questions on adjusting the plunger... but I'm going to get in the car later tonight and see if it makes sense while i'm stuck under the dash. question- did the throttle, and transmission seem "off" as well while driving this with BCI malfunction lights on? it seems to idle weird and not have any throttle control. I'm guessing it's all related to the computer thinking the brake is applied, and shutting down throttle and drivetrain. thx.It is located on the brake lever (above the peddle) it's not hard to get to but you will have to lay on your back to see under the dash and remove it. There are 2 sensors (BCI & Cruise Control) contacting the lever...the one on the top is the BCI and one you want to clean/replace. Just make sure you follow my instructions when you put it back in so that the plunger just barely pushes in 1/12 to 1/16 inch when the brake is fully released, otherwise it will engage the brakes and you won't be able to drive it (ask me how I know, lol). The one I replaced it with ($14 off ebay) has worked flawlessly since I installed it so I hope the problem is fixed.
I've had this issue twice now. I have 2019 Armada. Would not start and could not shift it out of park. It is a bad break switch causing these problems. This is the 2nd switch I've had gone bad, either a bad design or defective parts.Today while I was driving suddenly the BCI malfunction light came ON. I had to turn the engine off and fire it up again to make it go away. Anyone have this come up? Not sure why it popped up. Backup camera and sonar is functional.
Have you had any issues since you replaced the stop lamp switch? What about brake switch which several had posted with BCI malfunction?Took mine to Boulder, CO dealer service center. Master mechanic came out and looked at while I was there. Lights were all up on the dash and I didn't turn off the car. He said he had dealt with it a few times before on the same car. Here's a copy of what they replace. Replaced the stop lamp switch and everything is working well now. hopefully it doesn't return.![]()
Hi Craig, appreciate your reply! Armada is currently at dealership and I will definitely mention these two possible solutions. Is your Armada running fine after your last visit to solve BCI issue?Having same BCI issue. I have 2019 Platinum trim. How did all of you get this resolved??? Very angry this is happening with a 60k+ vehicle!!!
This is kind of what happens to mine (2017 SL 4x4.) Initially happened last week with my wife, she couldn't get the car started to pick up my daughter from a class. I thought maybe she just wasn't pushing down the brake hard enough or the stop lamp switch was going again (we had an issue previously on the freeway that turned out to be the stop lamp switch - replaced with updated version and everything seemed fine.)For the second time, my Armada is in the shop. It drives fine, I leave it for some time, then come back and it won't start. The dashboard flashes very briefly, but nothing happens. The first time the service guys ran every test and could not duplicate... so pushed it off as a fluke! This second time, I had 1 guy try to jump me and still nothing. Then after he left, I attempted to start it again. I heard a pop and then got the clicking as I tried to start it. Finally got it started with roadside assistance and took it straight to Nissan. Once again, they are not finding anything. All tests are being passed. I AM AT A LOSS. One service guy mentioned that there could be a faulty brake switch, apparently this is the 18 or 19th Armada seeing this problem.
ANYONE SEEING THIS PROBLEM. Ridiculous I have to try and fix my own truck!
Do you know what recall this is? Or what the part # for the sensor is?There is a recall for a sensor that drains the battery down after the vehicle is turned off. Happened to me several times...run in the store come back out and dead battery (had battery tested and it showed no signs of problems, just drained) then worked fine for a while before happening again for no apparent reason. Recall seems to have fixed the problem.
